[postgis-tickets] [PostGIS] #3167: Windows build broken, lwin_geojson.c undefined reference to json_..
trac at osgeo.org
Tue Jun 16 06:08:30 PDT 2015
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
okay it seems the main culprit is because I build json-c statically
instead of dynamically
and the
LDFLAGS += -no-undefined
causes it for some reason to try to build dynamically which it can't cause
I have no dll. I confirmed if I take that line out things work fine.
With that line in, I get this message:
*** Warning: This system can not link to static lib archive
/projects/json-c/rel-0.12w32gcc481/lib/libjson-c.la.
*** I have the capability to make that library automatically link in when
*** you link to this library. But I can only do this if you have a
*** shared version of the library, which you do not appear to have.
and the libjson-c.a no longer gets added to the link statement.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3167#comment:7>
