[postgis-tickets] [PostGIS] #3181: Output POINT EMPTY in WKB using NaN as coordinate values
PostGIS trac at osgeo.org
Thu Jun 25 13:43:23 PDT 2015
  Reporter:  pramsey      |      Owner:  pramsey
      Type:  enhancement  |     Status:  reopened
  Priority:  high         |  Milestone:  PostGIS 2.2.0
 Component:  postgis      |    Version:  trunk
Resolution:               |   Keywords:
Changes (by robe):
 * status:  closed => reopened
 * resolution:  fixed =>
Comment:
 broke sfcgal regress
  sfcgal/tickets .. failed (diff expected obtained:
 /projects/postgis/tmp/2.2.0dev_pg9.4_geos3.5.0dev_gdal2.0.0w64/test_116_diff)
 --- sfcgal/tickets_expected     2015-05-15 04:28:13 -0400
 /projects/postgis/tmp/2.2.0dev_pg9.4_geos3.5.0dev_gdal2.0.0w64/test_116_out
 2015-06-25 16:31:23 -0400
 @@ -184,7 +184,7 @@
  #1453.2|f
  #1454|t
  #1414|CURVEPOLYGON Z EMPTY
 -#1478|MULTIPOINT EMPTY
 +#1478|POINT EMPTY
  #745|GEOMETRYCOLLECTION(POLYGON((-72 42 1,-70 43 1,-71 41 1,-72 42 1)))
  #1450|POINT|POLYGON
  #1482|4326
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3181#comment:2>
