[postgis-tickets] [PostGIS] #3182: update docs and configure to reflect SFCGAL 1.1+ is required to build with SFCGAL
trac at osgeo.org
Thu Jun 25 21:21:58 PDT 2015
Reporter: robe | Owner: colivier
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.2.0
Component: sfcgal | Version: trunk
Keywords: |
Guys,
I'm assuming this is an intentional break, and I'm fine with that, but
configure has got to be fixed and so are the docs.
After the latest winds of changes to sfcgal (I'm assuming this one in
particular #3117 ) , I now get this error on winnie. I'm going to update
her SFCGAL, but so others don't scratch their heads in plane, please
update configure and docs to reflect the change:
http://postgis.net/docs/manual-
dev/postgis_installation.html#install_short_version
gcc -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-
statement -Wendif-labels -Wmissing-format-attribute -Wformat-security
-fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -O2 -shared
-static-libgcc -o postgis-2.2.dll postgis_module.o lwgeom_accum.o
lwgeom_spheroid.o lwgeom_ogc.o lwgeom_functions_analytic.o
lwgeom_inout.o lwgeom_functions_basic.o lwgeom_btree.o lwgeom_box.o
lwgeom_box3d.o lwgeom_geos.o lwgeom_sfcgal.o lwgeom_backend_api.o
lwgeom_geos_prepared.o lwgeom_geos_clean.o lwgeom_geos_relatematch.o
lwgeom_export.o lwgeom_in_gml.o lwgeom_in_kml.o lwgeom_in_geohash.o
lwgeom_in_geojson.o lwgeom_in_encoded_polyline.o lwgeom_triggers.o
lwgeom_dump.o lwgeom_dumppoints.o lwgeom_functions_lrs.o
lwgeom_functions_temporal.o long_xact.o lwgeom_sqlmm.o lwgeom_rtree.o
lwgeom_transform.o gserialized_typmod.o gserialized_gist_2d.o
gserialized_gist_nd.o gserialized_estimate.o geography_inout.o
geography_btree.o geography_measurement.o geography_measurement_trees.o
geometry_inout.o -Le:/jenkins/postgresql/rel/pg9.4w64gcc48/lib -Wl
,--allow-multiple-definition -Wl,--disable-auto-import -L/projects/libxml
/rel-libxml2-2.7.8w64gcc48/lib -Wl,--as-needed
../libpgcommon/libpgcommon.a ../liblwgeom/.libs/liblwgeom.a
-L/projects/geos/rel-3.5.0devw64gcc48/lib
-L/projects/proj/rel-4.9.1w64gcc48/lib -lgeos_c -lproj
-L/projects/json-c/rel-0.12w64gcc48/lib -ljson-c -L/projects/libxml/rel-
libxml2-2.7.8w64gcc48/lib -lxml2 -lws2_32 -L/projects/CGAL/rel-
sfcgal-1.0.5w64gcc48/lib -lSFCGAL -L/projects/CGAL/rel-
-Le:/jenkins/postgresql/rel/pg9.4w64gcc48/lib -lpostgres -lpgcommon
-lpgport -lxml2 -lwsock32 -lm -lws2_32 -Wl,--export-all-symbols -Wl
,--out-implib=libpostgis-2.2.a
lwgeom_sfcgal.o: In function `sfcgal_difference':
e:\jenkins\postgis\branches\2.2\postgis/lwgeom_sfcgal.c:534: undefined
reference to `sfcgal_geometry_difference'
lwgeom_sfcgal.o: In function `sfcgal_difference3D':
e:\jenkins\postgis\branches\2.2\postgis/lwgeom_sfcgal.c:563: undefined
reference to `sfcgal_geometry_difference_3d'
lwgeom_sfcgal.o: In function `sfcgal_union':
e:\jenkins\postgis\branches\2.2\postgis/lwgeom_sfcgal.c:591: undefined
reference to `sfcgal_geometry_union'
lwgeom_sfcgal.o: In function `sfcgal_union3D':
e:\jenkins\postgis\branches\2.2\postgis/lwgeom_sfcgal.c:620: undefined
reference to `sfcgal_geometry_union_3d'
lwgeom_sfcgal.o: In function `sfcgal_volume':
e:\jenkins\postgis\branches\2.2\postgis/lwgeom_sfcgal.c:642: undefined
reference to `sfcgal_geometry_volume'
collect2.exe: error: ld returned 1 exit status
e:/jenkins/postgresql/rel/pg9.4w64gcc48/lib/pgxs/src/makefiles/../../src/Makefile.shlib:391:
recipe for target `postgis-2.2.dll' failed
make[1]: *** [postgis-2.2.dll] Error 1
make[1]: Leaving directory `/projects/postgis/branches/2.2/postgis'
GNUmakefile:14: recipe for target `all' failed
make: *** [all] Error 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3182>
