[postgis-tickets] [PostGIS] #3180: topology regress failures on windows 9.4 64-bit
PostGIS trac at osgeo.org
Fri Jun 26 04:40:50 PDT 2015
  Reporter:  robe      |      Owner:  strk
      Type:  defect    |     Status:  assigned
  Priority:  blocker   |  Milestone:  PostGIS 2.2.0
 Component:  topology  |    Version:  trunk
Resolution:            |   Keywords:
Comment (by strk):
 Please check with r13715. The code was fetching a 64bit integer using
 DatumGetInt32... (on 64bit linux with PostgreSQL and PostGIS compiled
 using GCC everything worked nonetheless).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3180#comment:4>
