[postgis-tickets] [PostGIS] #2877: Revise configure to build make scripts for address_standardizer extension
trac at osgeo.org
Sat Jun 27 00:38:13 PDT 2015
Reporter: robe | Owner: robe
Type: enhancement | Status: new
Priority: high | Milestone: PostGIS 2.2.0
Component: pagc_address_parser | Version: trunk
Resolution: | Keywords:
Comment (by robe):
This is more or less done for main extenion, but I'm working on packaging
the address data as an extension. The tricky part is I've got to destroy
the existing files and replace with insert since the original uses COPY
commands which won't work in an extension install.
I was thinking of fiddling with the perl script, but decided its probably
just as easy to directly edit a bunch of inserts than fiddle with screwing
up the perl conversion with my limited skill in perl.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2877#comment:6>
