[postgis-tickets] [PostGIS] #3167: Windows build broken, lwin_geojson.c undefined reference to json_..
trac at osgeo.org
Sun Jun 28 14:56:30 PDT 2015
Reporter: robe | Owner: strk
Type: defect | Status: closed
Priority: blocker | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords:
Comment (by robe):
Okay I put back that line at r13732 as noted in #3170
I was able to still keep my static linking, by compiling json-c as usual
(with just --enable-static --disable-shared, so didn't need to recompile)
BUT - and not sure this is right I hacked the include/libjson-c.la
By changing line 11 that read:
# Names of this library.
library_names=''
to
library_names='libjson-c.a'
And that seemed to do the trick. I'm not knowledgeable enough to know why
this worked and couldn't find it described on web, but seemd to do the
trick for me.
I'll know for sure if Winnie passes thru all her tests. I only tested on
my mingw64-w64 9.4 dev instance.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3167#comment:13>
