[postgis-tickets] [PostGIS] #3058: picksplit method for column 1 of index "nd_geometry_idx" failed
PostGIS trac at osgeo.org
Mon Mar 2 08:25:56 PST 2015
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by strk):
 I believe it is _us_ setting 0 entries in one side:
 DEBUG:  switched to buffered GiST build; level step = 1, pagesPerBuffer =
 305
 NOTICE:  YYY below:2, above:0
 NOTICE:  XXX FOR d:2, below:0, above:141
 ERROR:  XXX direction:2, below: 0, above: 141, posmax:141
 The gserialized_gist_picksplit_badratios does not return TRUE for such
 configuration (maybe because it only does so if _all_ of the dimensions
 have that problem?). But then when looking for the plan giving us the most
 "even ratio" the code looks suspicious, really only checking for the max
 number of items in any of the two sides. Evidently 141 happens to be the
 biggest number, and that plane is picked, which has 0 on the other side:
   ** Now, what splitting plane gives us the most even ratio of
   ** entries in our child pages? Since each split region has been
 apportioned entries
   ** against the same number of total entries, the axis that has the
 smallest maximum
   ** number of entries in its regions is the most evenly distributed.
   ** TODO: what if the distributions are equal in two or more axes?
   for ( d = 0; d < ndims_pageunion; d++ )
     int posd = Max(pos[ABOVE(d)],pos[BELOW(d)]);
     if ( posd > posmax )
       direction = d;
       posmax = posd;
     if ( pos[BELOW(d)] == 0 || pos[ABOVE(d)] == 0 )
       lwnotice("XXX FOR d:%d, below:%d, above:%d", d, pos[BELOW(d)],
 pos[ABOVE(d)]);
 Should the difference between ABOVE and BELOW be considered instead, and
 the _minimum_ difference be taken as the best split ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3058#comment:8>
