[postgis-tickets] [PostGIS] #3058: picksplit method for column 1 of index "nd_geometry_idx" failed
trac at osgeo.org
Mon Mar 2 09:30:39 PST 2015
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: trunk
Keywords: |
Comment(by strk):
Actually, I could also test performance as I have the old index built and
could compare with the old and with the new.
Same queries are run against the same data, in one case the old index is
used (removing the new) and in the other case the new index is used
(removing the old). Indexes removal happens in a transaction which is
rolled back afterwards, so nothing is lost. Plans have been checked to all
use an index scan.
Runs with old index:
Total runtime: 18.324 ms
Total runtime: 16.792 ms
Total runtime: 635.775 ms
Total runtime: 11.026 ms
Total runtime: 15.693 ms
Runs with new index:
Total runtime: 16.001 ms
Total runtime: 31.227 ms
Total runtime: 192.585 ms
Total runtime: 11.787 ms
Total runtime: 26.770 ms
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3058#comment:10>
