[postgis-tickets] [PostGIS] #3066: [raster] PostGIS 2.1.5 compile issues with raster extensions
trac at osgeo.org
Mon Mar 2 10:51:46 PST 2015
Reporter: serbinsh | Owner: dustymugs
Type: defect | Status: new
Priority: high | Milestone:
Component: raster | Version: 2.1.x
Keywords: raster |
I am running into an issue attempting to compile PostGIS 2.1.5 with
PostgreSQL 9.4 on a SciLinx 6.5 server. I am using Proj 4.0.8, GEOS
3.4.2, and GDAL 1.11.2. The issue occurs during make in the
../postgis-2.1.5/raster/loader extension directory. Here is the error
output:
make[2]: Entering directory
`/data/software/src/postgis/postgis-2.1.5/raster/loader'
mpicc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I../rt_core
-I../../liblwgeom -I/data/software/proj/4.8.0/include
-I/data/software/gdal/1.11.2/include -I/data/software/geos/3.4.2/include
-c raster2pgsql.c
/bin/sh ../../libtool --mode=link mpicc -g -O2 -fPIC -DPIC -Wall
-Wmissing-prototypes -I../rt_core -I../../liblwgeom
-I/data/software/proj/4.8.0/include -I/data/software/gdal/1.11.2/include
-I/data/software/geos/3.4.2/include ../rt_core/librtcore.a
raster2pgsql.o ../../liblwgeom/liblwgeom.la
-L/data/software/gdal/1.11.2/lib -lgdal -L/data/software/geos/3.4.2/lib
-lgeos_c -lc -lm -o raster2pgsql
libtool: link: mpicc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes
-I../rt_core -I../../liblwgeom -I/data/software/proj/4.8.0/include
raster2pgsql.o -o .libs/raster2pgsql ../rt_core/librtcore.a
../../liblwgeom/.libs/liblwgeom.so -L/data/software/geos/3.4.2/lib
-L/software/src/openmpi/openmpi-1.6.4-gnu48/opal/mca/hwloc/hwloc132/hwloc/src
-L/data/software/proj/4.8.0/lib -L/data/software/json-c/0.11/lib
/data/software/proj/4.8.0/lib/libproj.so
/data/software/json-c/0.11/lib/libjson-c.so
/data/software/geos/3.4.2/lib/libgeos_c.so
/data/software/geos/3.4.2/lib/libgeos.so
/software/mpi/openmpi/1.6.4-gnu48/lib/libmpi_cxx.so
/software/mpi/openmpi/1.6.4-gnu48/lib/libmpi.so -ldl -lnsl -lutil
/usr/lib64/libtorque.so -lpthread -lrt -lxml2 -lz -lcrypto -lssl
/software/gcc-4.8.0/lib/../lib64/libstdc++.so -lc -lm -pthread -Wl,-rpath
-Wl,/usr/local/lib -Wl,-rpath -Wl,/data/software/proj/4.8.0/lib -Wl,-rpath
-Wl,/data/software/json-c/0.11/lib -Wl,-rpath
-Wl,/data/software/geos/3.4.2/lib -Wl,-rpath
-Wl,/software/mpi/openmpi/1.6.4-gnu48/lib -Wl,-rpath -Wl,/usr/lib64
-Wl,-rpath -Wl,/software/gcc-4.8.0/lib/../lib64
/data/software/gdal/1.11.2/lib/libgdal.so: undefined reference to
`GTIFAllocDefn'
`nc_inq_var_chunking'
`nc_def_var_chunking'
`nc_def_var_deflate'
`GTIFFreeDefn'
collect2: error: ld returned 1 exit status
make[2]: *** [raster2pgsql] Error 1
make[2]: Leaving directory
make[1]: *** [rtloader] Error 2
make[1]: Leaving directory
`/data/software/src/postgis/postgis-2.1.5/raster'
make: *** [all] Error 1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3066>
