[postgis-tickets] [PostGIS] #3065: Spatial index on LINESTRING not used under some circumstances
trac at osgeo.org
Tue Mar 3 03:13:28 PST 2015
Reporter: realityexists | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: 2.1.x
Keywords: |
Comment(by realityexists):
I don't know what to make of the EXPLAIN ANALYZE output. Here it is. In a
transaction:
Nested Loop (cost=0.00..893167397.30 rows=1083307 width=8) (actual
time=53.944..3005465.506 rows=821046 loops=1)
Join Filter: ((a.border && s.line) AND (_st_distance(a.border, s.line,
0::double precision, false) < 1e-05::double precision))
Rows Removed by Join Filter: 1624338609
-> Seq Scan on test_poly a (cost=0.00..1363.05 rows=14805 width=880)
(actual time=0.065..66.477 rows=14805 loops=1)
-> Materialize (cost=0.00..8264.72 rows=219515 width=36) (actual
time=0.006..46.816 rows=109771 loops=14805)
-> Seq Scan on _temp_line s (cost=0.00..5559.15 rows=219515
width=36) (actual time=0.124..68.740 rows=109771 loops=1)
Total runtime: 3005878.650 ms
Oustide of a transaction:
Nested Loop (cost=0.00..116283.23 rows=1083307 width=8) (actual
time=1.224..869916.660 rows=821046 loops=1)
(actual time=0.043..36.121 rows=14805 loops=1)
-> Index Scan using ix__temp_line_line on _temp_line s
(cost=0.00..7.69 rows=7 width=36) (actual time=1.642..58.708 rows=55
loops=14805)
Index Cond: (a.border && line)
Filter: (_st_distance(a.border, line, 0::double precision, false)
Rows Removed by Filter: 41
Total runtime: 870215.643 ms
Even with enable_seqscan=off the index is not used. EXPLAIN output (in a
transaction):
Nested Loop (cost=20000000000.00..20893167397.30 rows=1083307 width=8)
-> Seq Scan on test_poly a (cost=10000000000.00..10000001363.05
-> Materialize (cost=10000000000.00..10000008264.73 rows=219515
width=36)
-> Seq Scan on _temp_line s (cost=10000000000.00..10000005559.15
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3065#comment:5>
