[postgis-tickets] [PostGIS] #3068: Arbitrary "coord_dimension" for geometry_columns with unconstrained 4D point
trac at osgeo.org
Tue Mar 3 04:47:17 PST 2015
point
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: postgis | Version: 2.0.x
Keywords: |
Changes (by robe):
* milestone: PostGIS 2.0.7 => PostGIS 2.2.0
Comment:
I wouldn't change behavior like this in a micro. Is it the function or
the view or both that is bothering you? The thinking was that for people
who don't constrain their geometry columns in some way (and for views
based on tables that only have constraints), coord dimension of 2 is the
most likely assumption. I think that still holds true.
However I'd be willing to change if we test enough third-party tools to
confirm it does more good than harm. I still don't think this is an
appropriate change for a micro -- so pushing this to 2.2
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3068#comment:7>
