[postgis-tickets] [PostGIS] #3068: Arbitrary "coord_dimension" for geometry_columns with unconstrained 4D point
PostGIS trac at osgeo.org
Tue Mar 3 04:53:44 PST 2015
point
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.2.0
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
Comment(by robe):
 I should add, I'm okay with touching the postgis_typmod_dims even in
 micro. Now I am relooking at what you are saying.  THAT IS A BUG, and
 would probably significantly improve the performance of the view  if we
 changed it (to not assume 2).  The constraint should only kick in if
 absolutely postgis_typmod_dims is known to return no value, as it stands
 it's probably kicking in for most any table (a 2D which I think is a real
 performance killer)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3068#comment:9>
