[postgis-tickets] [PostGIS] #3071: CLUSTER on geometry index taking forever
trac at osgeo.org
Thu Mar 5 11:42:53 PST 2015
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Keywords: |
I'm pretty sure I've done a CLUSTER and tables bigger than this and it did
not take this long.
I grabbed building footprints from this
building footprints https://data.sfgov.org/Geographic-Locations-and-
Boundaries/Building-Footprints-Zipped-Shapefile-Format-/jezr-5bxm
and ran:
shp2pgsql -D -I -t 2D building_footprint data.sfo_buildings | psql -d
workshop_1
The data had a ton of self-intersections
so Ir an this:
UPDATE data.sfo_buildings
SET geom = ST_Multi(ST_MakeValid(geom))
WHERE NOT ST_IsValid(geom);
which was fine, and then proceeded to cluster
ALTER TABLE data.sfo_buildings
CLUSTER ON sfo_buildings_geom_idx;
CLUSTER data.sfo_buildings;
I've been waiting for 10 minutes already and the table has only got 80,000
some odd records. Much longer than I have patience for. I'm pretty sure
I've done an exercise like this with many more multipolygons and it was
way faster (under a minute)
I'll try to reproduce with a random dataset and also with PostGIS 2.1.5
This is running:
POSTGIS="2.2.0dev r13298" GEOS="3.5.0dev-CAPI-1.9.0 r4048" SFCGAL="1.0.5"
PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL 1.11.1, released 2014/09/24"
LIBXML="2.7.8" LIBJSON="0.12" RASTER PostgreSQL 9.4.1, compiled by Visual
C++ build 1800, 64-bit
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3071>
