[postgis-tickets] [PostGIS] #3072: ST_Intersects sfcgal implementation gives error with polyhedral surface
trac at osgeo.org
Thu Mar 5 19:41:40 PST 2015
Reporter: robe | Owner: colivier
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: sfcgal | Version: 2.1.x
Keywords: |
I can't compare to the built in ST_Intersects since that one throws a
polyhedralsurface not supported error.
I have this:
set postgis.backend = sfcgal;
WITH pa AS ( SELECT
ST_Extrude(ST_Force3D(ST_GeomFromText('MULTIPOLYGON(((6011980.6923649
2117710.26819432,6011983.40466805 2117690.92097183,
6011988.97899699 2117691.72493859,6012014.67481019
2117512.89736198,6011838.71290818 2117490.73975961,6011813.97754787
2117666.48492323,
6011961.83622488 2117687.8102276,6011958.87617183
2117707.03845887,6011980.6923649 2117710.26819432)))',2227)),0,0,860) As
geom ),
drone As ( SELECT
ST_Translate(
ST_Force3D(
ST_Transform(ST_GeomFromText('POINT(-122.4028
37.7952)',4326),2227) ),
0, 0, z) As geom, z
FROM generate_series(500,1000, 500) As z )
SELECT z
FROM drone INNER JOIN pa ON ST_Intersects(drone.geom, pa.geom);
I get this error:
NOTICE: During intersects(A,B) :
NOTICE: with A: POINT(6455232916477051/1073741824
2273757146426363/1073741824 500/1)
NOTICE: and B:
GEOMETRYCOLLECTION(POLYHEDRALSURFACE(((6455315114472671/1073741824
4547748172148997/2147483648 0/1,3227659013393001/536870912
4547706624305065/2147483648 0/1,3227662006088063/536870912
568463543851317/268435456 0/1,1613837900711365/268435456 227
This is using:
POSTGIS="2.2.0dev r13298" GEOS="3.5.0dev-CAPI-1.9.0 r4048" SFCGAL="1.0.5"
PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL 1.11.1, released 2014/09/24"
LIBXML="2.7.8" LIBJSON="0.12" RASTER
I was expecting this to give me the footprint intersection.
On another note -- I thought if I used ST_Extrude in 2.2, that the
ST_3DInteresects would give me a solid intersection (bit would be set to
solid), it seems not to. I'll bring this up on dev list.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3072>
