[postgis-tickets] [PostGIS] #3075: sfcgal ST_3DIntersects hangs on this query
trac at osgeo.org
Sat Mar 7 02:00:00 PST 2015
Reporter: robe | Owner: colivier
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: sfcgal | Version: 2.1.x
Keywords: |
I built a 3d building table using ST_Extrude and slapped on a 3D index.
CREATE INDEX idx_sfo_3dbuilds_geom
ON data.sfo_3dbuildings USING gist(geom gist_geometry_ops_nd);
When I do a query like this:
set postgis.backend=geos;
WITH drone_path AS (SELECT ST_GeomFromText('LINESTRING Z (6011567 2117852
12,6011567 2117860 50,
6011765 2117429 20, 6011765 2117500 100, 6011765 2118500 300, 6011800
2119500 30, 6012800 2129500 150)',2227) As geom)
SELECT b.gid
FROM data.sfo_3dbuildings As b INNER JOIN drone_path As d ON
ST_3DIntersects(b.geom, d.geom);
I get this answer:
gid
4354
4367
4379
4429
4449
4451
4509
4612
4836
4842
Which seems like a fairly respectible answer when I view it in my
x3dviewer - see attached image. Granted its a very messed up drone path I
have going on.
set postgis.backend=sfcgal;
When I switch to use sfcgal my postgres server goes into memory death and
I have to kill the connection.
Dataset and image is attached (buildings in red are those the native
ST_3DIntersects marks as collision targets)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3075>
