[postgis-tickets] [PostGIS] #3079: Bot failure building for PostgreSQL 9.5
PostGIS trac at osgeo.org
Sun Mar 15 20:58:09 PDT 2015
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.2.0
Component:  postgis  |     Version:  trunk
 Keywords:  pg9.5    |
 Debbie's weekly 9.5 regression run failed with this error.
 /pg9.5w64/include/postgresql/internal -D_GNU_SOURCE   -c -o lwgeom_geos.o
 lwgeom_geos.c
 lwgeom_geos.c: In function ‘errorIfGeometryCollection’:
 lwgeom_geos.c:1730: error: ‘DBL_DIG’ undeclared (first use in this
 function)
 lwgeom_geos.c:1730: error: (Each undeclared identifier is reported only
 once
 lwgeom_geos.c:1730: error: for each function it appears in.)
 make[1]: *** [lwgeom_geos.o] Error 1
 make[1]: Leaving directory
 `/var/lib/jenkins/workspace/postgis/regress_pgdev/branches/2.2/postgis'
 make: *** [all] Error 1
 This is compiling with following:
  PostGIS is now configured for x86_64-unknown-linux-gnu
  -------------- Compiler Info -------------
   C compiler:           gcc -g -O2
   C++ compiler:         g++ -g -O2
   SQL preprocessor:     /usr/bin/cpp -traditional-cpp -w -P
  -------------- Dependencies --------------
   GEOS config:
 /var/lib/jenkins/workspace/geos/rel-3.4.3devw64/bin/geos-config
   GEOS version:         3.4.3dev
   GDAL config:          /var/lib/jenkins/workspace/gdal/rel-2.0w64/bin
 /gdal-config
   GDAL version:         2.0.0
   PostgreSQL config:
 /var/lib/jenkins/workspace/pg/rel/pg9.5w64/bin/pg_config
   PostgreSQL version:   PostgreSQL 9.5devel
   PROJ4 version:        47
   Libxml2 config:       /usr/bin/xml2-config
   Libxml2 version:      2.7.8
   JSON-C support:       yes
   PCRE support:       yes
   PostGIS debug level:  0
   Perl:                 /usr/bin/perl
  --------------- Extensions ---------------
   PostGIS Raster:       enabled
   PostGIS Topology:     enabled
   SFCGAL support:       disabled
   Address Standardizer support:       enabled
  -------- Documentation Generation --------
   xsltproc:             /usr/bin/xsltproc
   xsl style sheets:     /usr/share/xml/docbook/stylesheet/nwalsh
   dblatex:              /usr/bin/dblatex
   convert:              /usr/bin/convert
   mathml2.dtd:          /usr/share/xml/schema/w3c/mathml/dtd/mathml2.dtd
 I'll test locally to verify it is a true issue and not something amiss
 with debbie and that it is 9.5 specific and not a geos error.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3079>
