[postgis-tickets] [PostGIS] #2626: Targeting to publish postgis and jts parser relases to Central maven repository
trac at osgeo.org
Mon Mar 16 01:48:55 PDT 2015
repository
Reporter: bergun | Owner: bergun
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: java | Version: 2.1.x
Keywords: Central maven repository |
Comment(by strk):
In that case the HOWTO_RELEASE file should be updated to add the
additional manual step.
But.. does the ant build do the right thing instead? That's the kind of
build you get by running "make" under the jdbc directory.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2626#comment:16>
