[postgis-tickets] [PostGIS] #3065: Spatial index on LINESTRING not used under some circumstances
trac at osgeo.org
Mon Mar 16 11:15:59 PDT 2015
Reporter: realityexists | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: 2.1.x
Keywords: |
Comment(by robe):
I ran this on my windows 64-bit dev
that has
POSTGIS="2.1.3 r12547" GEOS="3.5.0dev-CAPI-1.9.0 r3989" PROJ="Rel. 4.8.0,
6 March 2012" GDAL="GDAL 1.11.0, released 2014/04/16" LIBXML="2.7.8"
LIBJSON="UNKNOWN" RASTER PostgreSQL 9.3.3, compiled by Visual C++ build
1600, 64-bit
BEGIN; -- Problem doesn't happen outside of a transaction
DROP TABLE IF EXISTS _temp_line;
CREATE TEMP TABLE _temp_line AS
SELECT * FROM test_line;
-- Problem doesn't happen without this UPDATE.
-- Also doesn't happen without the seemingly-irrelevant timerange column.
UPDATE _temp_line SET segment_length = ST_Length(line);
CREATE INDEX ix__temp_line_line ON _temp_line USING GIST (line);
-- ANALYZE _sia_segment; -- This doesn't help!
EXPLAIN
SELECT ts_id, segment_id
FROM test_poly a
JOIN _temp_line s ON ST_Intersects(a.border, s.line);
and it behaved as expected
Nested Loop (cost=0.14..585.98 rows=328 width=8)
-> Seq Scan on test_poly a (cost=0.00..22.30 rows=1230 width=36)
-> Index Scan using ix__temp_line_line on _temp_line s
(cost=0.14..0.45 rows=1 width=36)
Index Cond: (a.border && line)
Filter: (_st_distance(a.border, line, 0::double precision, false)
< 1e-005::double precision)
I have to upgrade my dev to see if it's an issue with newer PostGIS and
PostgreSQL but at least as far as I can tell the issue does not show on
older.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3065#comment:9>
