[postgis-tickets] [PostGIS] #3080: PostgreSQL 9.5 regress failure on st_reclass
trac at osgeo.org
Mon Mar 16 19:45:00 PDT 2015
Reporter: robe | Owner: dustymugs
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.2.0
Component: raster | Version: trunk
Keywords: |
rt_reclass .. failed (diff expected obtained:
/var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_2_pg9.5w64/test_49_diff)
--- rt_reclass_expected 2014-04-26 22:51:48.000000000 -0700
/var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_2_pg9.5w64/test_49_out
2015-03-16 19:39:25.000000000 -0700
@@ -5,7 +5,11 @@
59|59|0
141|141|0
NOTICE: Invalid argument for reclassargset. Invalid expression of
reclassexpr for reclassarg of index 0 . Returning original raster
+NOTICE: Invalid argument for reclassargset. Invalid expression of
3.1415901184082|2.71828007698059|0
NOTICE: Invalid argument for reclassargset. Invalid band index (must use
1-based) for reclassarg of index 0 . Returning original raster
+NOTICE: Invalid argument for reclassargset. Invalid band index (must use
900|-900|900
This is against:
-------------- Dependencies --------------
GEOS config:
/var/lib/jenkins/workspace/geos/rel-3.4.3devw64/bin/geos-config
GEOS version: 3.4.3dev
GDAL config: /var/lib/jenkins/workspace/gdal/rel-2.0w64/bin
/gdal-config
GDAL version: 2.0.0
PostgreSQL config:
/var/lib/jenkins/workspace/pg/rel/pg9.5w64/bin/pg_config
PostgreSQL version: PostgreSQL 9.5devel
PROJ4 version: 47
Libxml2 config: /usr/bin/xml2-config
Libxml2 version: 2.7.8
JSON-C support: yes
PCRE support: yes
PostGIS debug level: 0
Perl: /usr/bin/perl
--------------- Extensions ---------------
PostGIS Raster: enabled
PostGIS Topology: enabled
SFCGAL support: disabled
Address Standardizer support: enabled
-------- Documentation Generation --------
xsltproc: /usr/bin/xsltproc
xsl style sheets: /usr/share/xml/docbook/stylesheet/nwalsh
dblatex: /usr/bin/dblatex
convert: /usr/bin/convert
mathml2.dtd: /usr/share/xml/schema/w3c/mathml/dtd/mathml2.dtd
I'm guessing this is a result of recent changes to PostgreSQL 9.5 code
base in past 7 or so days.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3080>
