[postgis-tickets] [PostGIS] #3081: Upgrade from 2.0.5: ERROR: type "rastbandarg" already exists
PostGIS trac at osgeo.org
Tue Mar 17 03:35:48 PDT 2015
 Reporter:  strk                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:
Component:  build/upgrade/install  |     Version:  2.1.x
 Keywords:                         |
Changes (by strk):
 * cc: robe (added)
Comment:
 The problem is that rtpostgis_upgrade.sql contains two different code
 blocks taking care of creating types. One is the postgis_proc_upgrade.pl
 generated block:
 -- Type rastbandarg -- LastUpdated: 201
 DO LANGUAGE 'plpgsql'
 $postgis_proc_upgrade$
 BEGIN
   IF 201 > version_from_num FROM _postgis_upgrade_info THEN
     EXECUTE $postgis_proc_upgrade_parsed_def$ CREATE TYPE rastbandarg AS (
   rast raster,
   nband integer
  $postgis_proc_upgrade_parsed_def$;
   END IF;
 END
 $postgis_proc_upgrade$;
 The other one is what I belive being a manually crafted block:
     -- create rastbandarg type if it does not exist
   IF NOT EXISTS(SELECT typname
     FROM pg_type
           WHERE typname = 'rastbandarg') THEN
         rast raster,
         nband integer
     END IF;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3081#comment:4>
