[postgis-tickets] [PostGIS] #2964: ST_OffSetCurve returns EMPTY geometries and other issues
trac at osgeo.org
Tue Mar 17 09:21:55 PDT 2015
Reporter: drbullit | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.1.6
Component: postgis | Version: 2.1.x
Resolution: invalid | Keywords: st_offsetcurve
Changes (by pramsey):
* status: new => closed
* resolution: => invalid
Comment:
The first issue is related directly to the second. An offset curve does
not just "shift" things (if you want that, maybe look at ST_Affine) it
produces a line that could be used along with other lines to produce a
cartographic rendering. For lines that "bend" to the right, the left-hand
offset will be somewhat longer than the line which will in turn be
somewhat longer than the right-hand offset.
Your initial example is offsetting a relatively "short" line by a
relatively "huge" amount, and since the line is concave in the direction
you're offsetting it, the offset shrinks away to nothing. Empty. I took
your example and just started reducing the offset distance until I got an
answer back. You'll see the picture of it attached.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2964#comment:2>
