[postgis-tickets] [PostGIS] #3084: shp2pgsql - illegal number format when specific system locale set
trac at osgeo.org
Wed Mar 18 07:30:37 PDT 2015
Reporter: infrag | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: 2.1.x
Keywords: |
I come across faulty behavior of shp2pgsql tool.
When system locale is set to some locale with i.e. different decimal
separator sign shp2pgsql produces faulty output.
I had my locale on ubuntu linux set to LANG=cs_CZ.UTF-8
then shp2pgsql output illegal format of GEOMETRY:
MULTIPOLYGON(((-759009,328 -1010948,384,-758995,543 -1010943,409, ...
You can see the collision of decimal delimiters with point separators.
When I changed LOCALE to LANG=en.UTF-8 the output was correct:
MULTIPOLYGON(((-759009.328 -1010948.384,-758995.543 -1010943.409,
The output of shp2pgsql should be locale independent since only one number
format is acceptable by postgres/postgis.
Similar faults could exist for various locales and various types which
should be output.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3084>
