[postgis-tickets] [PostGIS] #3031: "POINT EMPTY" as WKB defaults to "MULTIPOINT EMPTY" when restoring with copy and failing validation
PostGIS trac at osgeo.org
Thu Mar 19 16:55:35 PDT 2015
 Reporter:  jeanchristophesaville           |       Owner:  pramsey
     Type:  defect                          |      Status:  new
 Priority:  medium                          |   Milestone:  PostGIS 2.1.6
Component:  postgis                         |     Version:  2.1.x
 Keywords:  POINT EMPTY , MULTIPOINT EMPTY  |
Comment(by pramsey):
 OK, a patch for this at r13359. The patch is actually a suggestion from
 strk, to just allow MULTIPOINT EMPTY inputs a special pass through the
 typmod checker. It turned out to be less invasive code than I feared, so I
 went for that. The reason I did was to avoid emitting POINT(Nan nan) for
 our WKB output, which could potentially break downstream applications not
 expecting such a fun construct.
 Question: for trunk, do we go to POINT(nan nan) or keep our funny little
 hack in place?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3031#comment:11>
