[postgis-tickets] [PostGIS] #3031: "POINT EMPTY" as WKB defaults to "MULTIPOINT EMPTY" when restoring with copy and failing validation
trac at osgeo.org
Thu Mar 19 20:41:04 PDT 2015
Reporter: jeanchristophesaville | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.6
Component: postgis | Version: 2.1.x
Keywords: POINT EMPTY , MULTIPOINT EMPTY |
Comment(by robe):
I looked at the regress and your failures here:
http://debbie.postgis.net:8080/job/PostGIS_Regress/5936/consoleFull
I guess the question is if we need to change the test or just the regress
output or your code. I thinkyou need to change your code (as its still not
right, but the test output needs to be changed as well since it assumes
screwed up behavior which we are trying to fix)
So here is how you read it. ( If I read this right, then I've probably
been spending way too much time talking with strk :) )
pattern is:
table_to_insert|srid_of_geom|type_of_geom|zmflag_geom|out_status
for out_status:
OK means text insert pass
KO means text insert fail
BOK is binary insert pass (binary is from a COPY proces so the equivalent
of our restore)
BKO is binary insert failure
GOK is text geography pass, GKO: geography plain text failure etc.
and sample of putput from debbie
-point|0|Point|0|KO-BKO-GKO:-BGKO
+point|0|Point|0|OK-BKO-GOK-BGKO
-pointm4326|0|Point|1|KO-BKO-GKO:-BGKO
+pointm4326|0|Point|1|OK-BKO-GOK-BGKO
So from the above assuming I am reading these okay, I'm a little concerned
about the fact that you can do a text rep insert but not a binary as I
thought this was supposed to fix that issue.
I could very well be misreading this. But I would expect the answers to
be for new
not the same as the old, but not what you are emitting
--this is what it should be
point|0|Point|0|OK-BOK-GOK-BGOK
-- this is what the old returns
-- this is still wrong (assume this is with your NAN NAN)
To quickly test this is what I get with current which is wrong behavior
(but what current emits)
CREATE SCHEMA tm;
CREATE TABLE tm.point(id serial, g geometry(point), gg geography(point);
-- note this is mimicking strk's test without resorting to backup and
restore
(this test is a bit flawed as you really aren't testing POINT EMPTY but
POINT EMTPY casted to geomety casted as text to unknown so it's dumb luck
the answers look agreeable
-- meh KO
-- ERROR: Geometry type (MultiPoint) does not match column type (Point)
********** Error **********
INSERT INTO tm.point(g)
VALUES('POINT EMPTY'::geometry::text || '');
-- meh GKO
INSERT INTO tm.point(gg)
VALUES('POINT EMPTY'::geography::text || '');
-- meh KO, BGKO
INSERT INTO tm.point(g, gg)
VALUES('POINT EMPTY'::geometry::bytea, 'POINT EMPTY'::geography::bytea);
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3031#comment:17>
