[postgis-tickets] [PostGIS] #3089: [RASTER] regress tests on 'loader' fail
trac at osgeo.org
Tue Mar 24 00:21:19 PDT 2015
Reporter: kain | Owner: dustymugs
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.7
Component: raster | Version: 2.1.x
Keywords: |
I cannot pass the regression tests of raster loader, given error:
loader/Basic .. failed (test: running raster2pgsql:
/tmp/pgis_reg/loader.err)
loader/BasicCopy .. failed (test: running raster2pgsql:
loader/BasicFilename .. failed (test: running raster2pgsql:
in /tmp/pgis_reg/loader.err,
/home/kain/postgis-2.1.5/regress/../raster/loader/raster2pgsql:
/usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by
/usr/local/lib/libgdal.so.1)
/home/kain/workspace/metro/cdb-
pg/contrib/postgis-2.1.5/regress/../raster/loader/raster2pgsql:
/usr/local/lib/libgeos-3.4.2.so)
/usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by
Environments:
1. Rhel 5, PostgreSQL 9.3.5, PostGIS 2.1.5
2. GCC
gcc -print-libgcc-file-name
/opt/gcc-4.4.2/lib/gcc/x86_64-unknown-linux-gnu/4.4.2/libgcc.a
ll /opt/gcc-4.4.2/lib64/libstdc++.so.6
/opt/gcc-4.4.2/lib64/libstdc++.so.6 -> libstdc++.so.6.0.13
3. ll /usr/lib64/libstdc++.so.6
/usr/lib64/libstdc++.so.6 -> libstdc++.so.6.0.8
4. libtool
# Run-time system search path for libraries
sys_lib_dlsearch_path_spec="/lib64 /usr/lib64 "
I guess:
1. I've download a separated GCC
2. libgdal, libgeos are compiled with newer GLIBCXX of this GCC
3. while raster2pgsql searches for the older GLIBCXX of the system's.
Remark:
'''I have not met this issue in PostGIS 2.1.4 and earlier versions. It
occurs on PostGIS 2.1.5. Any suggestions for me?'''
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3089>
