[postgis-tickets] [PostGIS] #3089: [RASTER] regress tests on 'loader' fail
PostGIS trac at osgeo.org
Tue Mar 24 19:15:50 PDT 2015
  Reporter:  kain     |       Owner:  dustymugs
      Type:  defect   |      Status:  closed
  Priority:  medium   |   Milestone:  PostGIS 2.1.7
 Component:  raster   |     Version:  2.1.x
Resolution:  invalid  |    Keywords:
Comment(by kain):
 Replying to [comment:1 dustymugs]:
 > This question is better asked in the postgis-users ML.
 > It looks like libgdal and libgeos cannot find your different glibc
 libraries. You may need to recompile everything to your current glibc
 Thanks for your valuable suggestions. I'm not sure whether should I re-
 submit it to postgis-users ML, because, at the same version,
 PostGIS/loader have not met this issue, but PostGIS/Raster/loader met
 separately. But I'll try to re-compile libgdal.
 Now my solution is: remove /lib/lib64 from the relink_command of
 “raster2pgsql”, then everything is OK.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3089#comment:2>
