[postgis-tickets] [PostGIS] #3092: Slow performance of geometry_columns in PostGIS >= 2
trac at osgeo.org
Thu Mar 26 11:26:31 PDT 2015
Reporter: rouault | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.7
Component: postgis | Version: 2.0.x
Keywords: |
Original discussion in this thread http://lists.osgeo.org/pipermail/gdal-
dev/2015-March/041299.html
Querying geometry_columns exhibits poor performance (perhaps quadratic in
number of spatial tables) due to geometry_columns potentially calling
postgis_constraint_dims(), postgis_constraint_srid()
and postgis_constraint_type(), because each causes a SELECT to be executed
for each row if some typmod constraints are missing.
The following request gives similar information but much faster:
select c.relname,
a.attname,
t.typname,
postgis_typmod_dims(a.atttypmod) dim,
postgis_typmod_srid(a.atttypmod) srid,
postgis_typmod_type(a.atttypmod)::text typ,
array_agg(s.consrc)::text
FROM pg_class c join pg_attribute a on a.attrelid=c.oid
join pg_namespace n on c.relnamespace = n.oid
AND (c.relkind = 'r'::"char" OR c.relkind = 'v'::"char" OR
c.relkind = 'm'::"char" OR c.relkind = 'f'::"char")
AND NOT ( n.nspname = 'public' AND c.relname =
'raster_columns' )
join pg_type t on a.atttypid = t.oid and (t.typname =
'geometry'::name OR t.typname = 'geography'::name)
left join pg_constraint s on s.connamespace = n.oid AND
s.conrelid = c.oid
AND a.attnum = ANY (s.conkey)
AND (s.consrc LIKE '%geometrytype(% = %' OR
s.consrc LIKE '%ndims(% = %' OR s.consrc LIKE '%srid(% = %')
GROUP BY c.relname, a.attname, t.typname, dim, srid, typ, c.oid
ORDER BY c.oid
Some analysis of the aggregated constraints similar to what is done in
postgis_constraint_XXXX() should be done to merge that info with the one
of postgis_typmod_XXXX()
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3092>
