[postgis-tickets] [PostGIS] #3093: st_estimatedextent error with mixed case table names
trac at osgeo.org
Mon Mar 30 19:22:33 PDT 2015
Reporter: lpercich | Owner: pramsey
Type: defect | Status: closed
Priority: low | Milestone: PostGIS 2.1.7
Component: postgis | Version: 2.1.x
Resolution: wontfix | Keywords:
Changes (by robe):
* status: new => closed
* resolution: => wontfix
Comment:
I'm marking this as a wontfix. This has been the behavior for quite some
time and I think fixing it for you will break it for others who assume
that tables should be quoted if you want case sensitive behavior.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3093#comment:1>
