[postgis-tickets] [PostGIS] #2083: ST_RemEdgeModFace performance review
trac at osgeo.org
Mon Mar 30 23:30:16 PDT 2015
Reporter: strk | Owner: strk
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: topology | Version: 2.0.x
Keywords: |
Comment(by laopsahl):
Hi
After adding the index topo_ar5_sysdata.relation(abs(element_id)) the
performance is much better for a single select the time goes from more
than 3000 ms to around 20-40 ms. In the layer we are testing the
topo_ar5_sysdata.relation which contains 27794698 rows. For the end user
the update time goes down from 30 seconds to about 1 second for a user
that that is drawing simple polygon to update this layer.
Her is the explain with the functional index added
explain analyze SELECT r.* FROM topo_ar5_sysdata.relation r,
topology.layer l WHERE l.topology_id = 21 AND l.level = 0 AND
l.layer_id = r.layer_id AND abs(r.element_id) = 30145 AND r.element_type
= 2
QUERY PLAN
Hash Join (cost=1450.51..64998.02 rows=100884 width=16) (actual
time=0.061..0.066 rows=1 loops=1)
Hash Cond: (r.layer_id = l.layer_id)
-> Bitmap Heap Scan on relation r (cost=1449.96..63610.31 rows=100884
width=16) (actual time=0.027..0.032 rows=1 loops=1)
Recheck Cond: (abs(element_id) = 30145)
Filter: (element_type = 2)
Rows Removed by Filter: 1
-> Bitmap Index Scan on
opo_ar5_sysdata_relation_abs_element_id_idx (cost=0.00..1424.74
rows=138973 width=0) (actual time=0.019..0.019 rows=2 loops=1)
Index Cond: (abs(element_id) = 30145)
-> Hash (cost=0.53..0.53 rows=2 width=4) (actual time=0.023..0.023
rows=2 loops=1)
Buckets: 1024 Batches: 1 Memory Usage: 1kB
-> Seq Scan on layer l (cost=0.00..0.53 rows=2 width=4) (actual
time=0.016..0.019 rows=2 loops=1)
Filter: ((topology_id = 21) AND (level = 0))
Total runtime: 0.126 ms
(13 rows)
To avoid extra index I may also use a or, but that only works a long as
most of the element_id > 0. I have not seen any rows with a value below
zero yet.
< || ' AND abs(r.element_id) = e.edge_id';
> || ' AND ((r.element_id >-1 AND r.element_id = e.edge_id) OR (
r.element_id < 0 AND abs(r.element_id) = e.edge_id))';
I go for the functional index now and that may also cover other cases that
I have not seen in the logs yet.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2083#comment:6>
