[postgis-tickets] [PostGIS] #2358: Add post-check phase to PostGIS build (installcheck)
trac at osgeo.org
Mon May 4 02:43:35 PDT 2015
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.2.0
Component: build/upgrade/install | Version: 2.0.x
Resolution: | Keywords:
Comment (by strk):
run_test.pl is already able to perform post-install check via the
--extension switch. Do we want to also test for script-based post-install
checks ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2358#comment:5>
