[postgis-tickets] [PostGIS] #3105: sfcgal legacy test via extension: ERROR: attempt to redefine parameter "postgis.backend
trac at osgeo.org
Mon May 4 02:58:59 PDT 2015
"postgis.backend
Reporter: strk | Owner: colivier
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: sfcgal | Version: trunk
Keywords: |
cd regress
./run_test.pl -v --sfcgal --extension sfcgal/legacy.sql
sfcgal/legacy .. failed (diff expected obtained:
/tmp/pgis_reg/test_1_diff)
--- sfcgal/legacy_expected 2015-03-28 11:16:04.798484842 +0100
+++ /tmp/pgis_reg/test_1_out 2015-05-04 11:57:26.474192034 +0200
@@ -1,21 +1,73 @@
+psql:00-regress-install/share/contrib/postgis/legacy.sql:654: ERROR:
attempt to redefine parameter "postgis.backend"
+psql:00-regress-install/share/contrib/postgis/legacy.sql:678: ERROR:
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3105>
