[postgis-tickets] [PostGIS] #3141: cunit failures on twkb on winnie
PostGIS trac at osgeo.org
Thu May 28 10:48:02 PDT 2015
  Reporter:  robe      |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  critical  |  Milestone:  PostGIS 2.2.0
 Component:  postgis   |    Version:  trunk
Resolution:            |   Keywords:
Description changed by robe:
Old description:
> Haven't verified this myself but suddenly seeing this error on winnie
> when regressing 9.4 VC++ 64-bit:
>  Test: test_twkb_in_precision ...FAILED
>     1. cu_in_twkb.c:220  - CU_ASSERT_STRING_EQUAL(hex_a,hex_b)
>     2. cu_in_twkb.c:220  - CU_ASSERT_STRING_EQUAL(hex_a,hex_b)
> started showing after r13573
New description:
 Haven't verified this myself but suddenly seeing this error on winnie when
 started showing after r13573,  r13572
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3141#comment:1>
