[postgis-tickets] [PostGIS] #3141: cunit failures on twkb on winnie
PostGIS trac at osgeo.org
Thu May 28 14:41:44 PDT 2015
  Reporter:  robe      |      Owner:  pramsey
      Type:  defect    |     Status:  closed
  Priority:  critical  |  Milestone:  PostGIS 2.2.0
 Component:  postgis   |    Version:  trunk
Resolution:  fixed     |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 Okay your change at r13578 seems to have fixed my 64-bit issue.  The
 32-bit 9.4 on winnie is still failing, but that has been failing for
 sometime so might be something on my end.
 I'll test that one out before I complain.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3141#comment:2>
