[postgis-tickets] [PostGIS] #2093: Add extra policy argument to control ST_Simplify behavior
trac at osgeo.org
Thu May 28 11:46:03 PDT 2015
Reporter: robe | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by pramsey):
OK then, in the spirit of **improvement** then, I've added an extra
parameter to control collapses. I've also changed the LINESTRING collapse
behavior to return NULL on collapse instead of an illegal one-point line.
I've also changed both LINESTRING and POLYGON to return NULL when fed an
EMPTY input.
In the presence of the "preserve collapsed" parameter, the function will
now return at a minimum 4 point polygons and 2 point lines.
Concerns?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2093#comment:32>
