[postgis-tickets] [PostGIS] #3142: PostGIS 2.2 trunk build fail
trac at osgeo.org
Thu May 28 22:57:19 PDT 2015
Reporter: darkblueb | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Keywords: build |
undefined symbol: '''geod_init'''
psql (9.3.5)
Type "help" for help.
user=# \c postgis22_test
You are now connected to database "postgis22_test" as user "user".
postgis22_test=# create extension postgis <TAB>
postgis postgis_tiger_geocoder postgis_topology
postgis22_test=# create extension postgis;
ERROR: could not load library
"/usr/lib/postgresql/9.3/lib/postgis-2.2.so":
/usr/lib/postgresql/9.3/lib/postgis-2.2.so: undefined symbol: geod_init
Setup
PostgreSQL 9.3.5 on i686-pc-linux-gnu, compiled by gcc (Ubuntu
4.8.2-19ubuntu1) 4.8.2, 32-bit
PostGIS is now configured for i686-pc-linux-gnu
-------------- Compiler Info -------------
C compiler: gcc -g -O2
C++ compiler: g++ -g -O2
SQL preprocessor: /usr/bin/cpp -traditional-cpp -w -P
-------------- Dependencies --------------
GEOS config: /usr/local/bin/geos-config
GEOS version: 3.5.0dev
GDAL config: /usr/bin/gdal-config
GDAL version: 1.11.1
PostgreSQL config: /usr/bin/pg_config
PostgreSQL version: PostgreSQL 9.3.7
PROJ4 version: 49
Libxml2 config: /usr/bin/xml2-config
Libxml2 version: 2.9.1
JSON-C support: yes
PCRE support: yes
PostGIS debug level: 0
Perl: /usr/bin/perl
--------------- Extensions ---------------
PostGIS Raster: enabled
PostGIS Topology: enabled
SFCGAL support: disabled
Address Standardizer support: enabled
-------- Documentation Generation --------
xsltproc:
xsl style sheets:
dblatex:
convert:
mathml2.dtd: http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
user at lubase-1404:~/srcs/postgis_trunk$ svn info
Path: .
Working Copy Root Path: /home/user/srcs/postgis_trunk
URL: http://svn.osgeo.org/postgis/trunk
Relative URL: ^/trunk
Repository Root: http://svn.osgeo.org/postgis
Repository UUID: b70326c6-7e19-0410-871a-916f4a2858ee
Revision: 13578
Node Kind: directory
Schedule: normal
Last Changed Author: pramsey
Last Changed Rev: 13578
Last Changed Date: 2015-05-28 13:25:11 -0700 (Thu, 28 May 2015)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3142>
