[postgis-tickets] [PostGIS] #3142: PostGIS 2.2 trunk build fail
PostGIS trac at osgeo.org
Fri May 29 06:53:24 PDT 2015
  Reporter:  darkblueb  |      Owner:  pramsey
      Type:  defect     |     Status:  closed
  Priority:  medium     |  Milestone:  PostGIS 2.2.0
 Component:  postgis    |    Version:  trunk
Resolution:  invalid    |   Keywords:  build
Changes (by pramsey):
 * status:  new => closed
 * resolution:   => invalid
Comment:
 You've got two copies of proj on your system, a 4.9 version from which the
 header is being found on build and a lower version that is actually being
 found by the linker at runtime.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3142#comment:1>
