[postgis-tickets] [PostGIS] #3361: gserialized_from_lwgeom takes is_geodetic arg but does nothing with it, geography_serialize may give you a geometry if not careful
PostGIS trac at osgeo.org
Sun Nov 8 09:13:18 PST 2015
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 2.3.0
Component:  postgis  |    Version:  trunk
 Keywords:           |
 This is not so much a bug as a change the code to keep my sanity and so
 that other developers don't fall into a wtf trap.
 In hoping threw the wonderland of gserialized I ended up in the rabbit
 hole of
 gserialized_from_lwgeom(LWGEOM *  geom,int  is_geodetic, size_t *  size )
 in g_serialized c.
 http://postgis.net/docs/doxygen/2.3/da/d21/g__serialized_8c_a0b9fd37dce2089c4fecb8a23ed102323.html#a0b9fd37dce2089c4fecb8a23ed102323
 All roads from geometry and geography eventually lead to this function,
 and I was puzzled why every call would both do a
 lwgeom_set_geodetic(lwgeom, true);
 and then still pass along this is_geodetic bit.
 On closer inspection -- that is_geodetic bit is never used, just always
 ignored like some vestigial cecum that turned into a useless appendix.  In
 fact the internal bit in lwgeom is always used, so we should just get rid
 of this argument.
 I should add -- geography_serialize(lwgeom); I thought would be smart
 enough to set the geodetic bit too from the name of the function as isn't
 the point to get a geography serialized out of an lwgeom, nope.  If you
 feed in an lwgeom that is not geodetic, you end up with a gserialized that
 is not geodetic also.
 Anyway I'd like to change at the very least that gserialized_from_lwgeom
 and changed geography_serialize to guarantee always getting back a
 geography.  But I would like to get some opinions before I do that.  Of
 course I would only do this in 2.3 and not backport.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3361>
