[postgis-tickets] [PostGIS] #3361: gserialized_from_lwgeom takes is_geodetic arg but does nothing with it, geography_serialize may give you a geometry if not careful
trac at osgeo.org
Sun Nov 8 09:13:44 PST 2015
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.3.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Description changed by robe:
Old description:
> This is not so much a bug as a change the code to keep my sanity and so
> that other developers don't fall into a wtf trap.
> In hoping threw the wonderland of gserialized I ended up in the rabbit
> hole of
> gserialized_from_lwgeom(LWGEOM * geom,int is_geodetic, size_t * size )
> in g_serialized c.
> http://postgis.net/docs/doxygen/2.3/da/d21/g__serialized_8c_a0b9fd37dce2089c4fecb8a23ed102323.html#a0b9fd37dce2089c4fecb8a23ed102323
> All roads from geometry and geography eventually lead to this function,
> and I was puzzled why every call would both do a
> lwgeom_set_geodetic(lwgeom, true);
> and then still pass along this is_geodetic bit.
> On closer inspection -- that is_geodetic bit is never used, just always
> ignored like some vestigial cecum that turned into a useless appendix.
> In fact the internal bit in lwgeom is always used, so we should just get
> rid of this argument.
> I should add -- geography_serialize(lwgeom); I thought would be smart
> enough to set the geodetic bit too from the name of the function as isn't
> the point to get a geography serialized out of an lwgeom, nope. If you
> feed in an lwgeom that is not geodetic, you end up with a gserialized
> that is not geodetic also.
> Anyway I'd like to change at the very least that gserialized_from_lwgeom
> and changed geography_serialize to guarantee always getting back a
> geography. But I would like to get some opinions before I do that. Of
> course I would only do this in 2.3 and not backport.
New description:
In hopping threw the wonderland of gserialized I ended up in the rabbit
hole of
in g_serialized c.
ignored like some vestigial cecum that turned into a useless appendix. In
fact the internal bit in lwgeom is always used, so we should just get rid
of this argument.
feed in an lwgeom that is not geodetic, you end up with a gserialized that
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3361#comment:1>
