[postgis-tickets] [PostGIS] #3082: Error soft-upgrading from 2.1 to 2.2
PostGIS trac at osgeo.org
Wed Nov 11 02:43:14 PST 2015
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  reopened
  Priority:  medium                 |  Milestone:  PostGIS 2.2.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:                         |   Keywords:
Comment (by lrssvt):
 2.2.0dev has always worked very well, no problem. A while ago I did
 upgrade constantly from trunk, now a little less, so yes 2.2.0dev is an
 upgrading from 2.1.0dev.
 Tweaking the conditional in the script does the job, thanks (I had to
 tweak type agg_count as well)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3082#comment:12>
