[postgis-tickets] [PostGIS] #3082: Error soft-upgrading from 2.1 to 2.2
trac at osgeo.org
Wed Nov 11 03:09:05 PST 2015
Reporter: strk | Owner: strk
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.2.0
Component: build/upgrade/install | Version: trunk
Resolution: fixed | Keywords:
Changes (by strk):
* status: reopened => closed
* resolution: => fixed
Comment:
Another way could have been to replace your postgis_scripts_installed()
to pretend you were running 2.1 instead of 2.2. Anyway, I guess it's too
late for testing that now ...
Closing again, assuming the "cheating" approach would work (if you can
test and it doesn't work, reopen again).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3082#comment:13>
