[postgis-tickets] r14416 - remove inaccurate comments (the tests are always performed, and we're calculating a box if we don't have one)
Daniel Baston
dbaston at gmail.com
Sun Nov 22 06:26:47 PST 2015
Author: dbaston
Date: 2015-11-22 06:26:47 -0800 (Sun, 22 Nov 2015)
New Revision: 14416
trunk/postgis/lwgeom_geos.c
Modified: trunk/postgis/lwgeom_geos.c
--- trunk/postgis/lwgeom_geos.c 2015-11-22 06:16:57 UTC (rev 14415)
+++ trunk/postgis/lwgeom_geos.c 2015-11-22 14:26:47 UTC (rev 14416)
@@ -1946,7 +1946,6 @@
* short-circuit 1: if geom2 bounding box does not overlap
* geom1 bounding box we can prematurely return FALSE.
- * Do the test IFF BOUNDING BOX AVAILABLE.
if ( gserialized_get_gbox_p(geom1, &box1) &&
gserialized_get_gbox_p(geom2, &box2) )
@@ -2021,7 +2020,6 @@
** short-circuit 1: if geom2 bounding box is not completely inside
** geom1 bounding box we can prematurely return FALSE.
- ** Do the test IFF BOUNDING BOX AVAILABLE.
@@ -2156,7 +2154,6 @@
* short-circuit: if geom2 bounding box is not completely inside
@@ -2245,7 +2242,6 @@
@@ -2399,7 +2395,6 @@
* short-circuit 1: if geom1 bounding box is not completely inside
* geom2 bounding box we can prematurely return FALSE.
@@ -2519,7 +2514,6 @@
@@ -2592,7 +2586,6 @@
@@ -2749,7 +2742,6 @@
@@ -2817,7 +2809,6 @@
* geom1 bounding box we can prematurely return TRUE.
