[postgis-tickets] [PostGIS] #3099: ST_curveToLine bad conversion for some arcs
trac at osgeo.org
Tue Nov 24 23:47:58 PST 2015
Reporter: claudeunger | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.1.9
Component: postgis | Version: 2.1.x
Resolution: | Keywords: ST_curveToLine
Comment (by tiiipponen):
I can try to deliver such a automated testcase if I understand what you
want.[[BR]]
I already send two short Python codes. [[BR]]
Would you like to have some PostGIS data dump?[[BR]]
When you look data visually for example with QGIS, you can see bad
results.[[BR]]
If you want something else, let me know. I try to give for you everything
you need.[[BR]]
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3099#comment:13>
