[postgis-tickets] [PostGIS] #3099: ST_curveToLine bad conversion for some arcs
PostGIS trac at osgeo.org
Wed Nov 25 04:23:19 PST 2015
  Reporter:  claudeunger  |      Owner:  pramsey
      Type:  defect       |     Status:  new
  Priority:  critical     |  Milestone:  PostGIS 2.1.9
 Component:  postgis      |    Version:  2.1.x
Resolution:               |   Keywords:  ST_curveToLine
Comment (by robe):
 tiipponen,
 Here is our FAQ on how to prepare tests - For lwgeom stuff, we'd need both
 a cunit test and a postgresql test.
 Cunit
 https://trac.osgeo.org/postgis/wiki/DevWikiCUnit
 PostgreSQL
 https://trac.osgeo.org/postgis/wiki/DevWikiPGRegress
 Ideally we would want the smallest example you can think of that would
 reproduce the issue  (maybe on this ticket, but them side by side so they
 can compare), so perhaps the example above, but maybe instead of the
 default number of points to represent an arc, you passed in a smaller
 number.
 Using this form of the function
  ST_CurveToLine(geometry curveGeom, integer segments_per_qtr_circle);
 I should add, we normally don't ask this of people reporting bugs or
 giving patches for fixes, so take it as a BIG compliment, that we think
 you are capable of doing this :).
 Normally I'd just do this myself, but I don't work much in curve area and
 I think pramsey who works on this part is on vacation.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3099#comment:14>
