[postgis-tickets] r14460 - Remove warnings building against 9.6, closes #3385
Paul Ramsey
pramsey at cleverelephant.ca
Mon Nov 30 10:39:50 PST 2015
Author: pramsey
Date: 2015-11-30 10:39:50 -0800 (Mon, 30 Nov 2015)
New Revision: 14460
trunk/libpgcommon/lwgeom_transform.c
trunk/postgis/lwgeom_geos_prepared.c
Modified: trunk/libpgcommon/lwgeom_transform.c
--- trunk/libpgcommon/lwgeom_transform.c 2015-11-30 17:54:09 UTC (rev 14459)
+++ trunk/libpgcommon/lwgeom_transform.c 2015-11-30 18:39:50 UTC (rev 14460)
@@ -92,7 +92,13 @@
static void PROJ4SRSCacheDelete(MemoryContext context);
static void PROJ4SRSCacheReset(MemoryContext context);
static bool PROJ4SRSCacheIsEmpty(MemoryContext context);
+#if POSTGIS_PGSQL_VERSION >= 96
+static void PROJ4SRSCacheStats(MemoryContext context, int level, bool print, MemoryContextCounters *totals);
+#else
static void PROJ4SRSCacheStats(MemoryContext context, int level);
+#endif
#ifdef MEMORY_CONTEXT_CHECKING
static void PROJ4SRSCacheCheck(MemoryContext context);
#endif
@@ -165,7 +171,11 @@
static void
+PROJ4SRSCacheStats(MemoryContext context, int level, bool print, MemoryContextCounters *totals)
+#else
+#endif
* Simple stats display function - we must supply a function since this call is mandatory according to tgl
Modified: trunk/postgis/lwgeom_geos_prepared.c
--- trunk/postgis/lwgeom_geos_prepared.c 2015-11-30 17:54:09 UTC (rev 14459)
+++ trunk/postgis/lwgeom_geos_prepared.c 2015-11-30 18:39:50 UTC (rev 14460)
@@ -86,7 +86,12 @@
static void PreparedCacheReset(MemoryContext context);
static void PreparedCacheDelete(MemoryContext context);
static bool PreparedCacheIsEmpty(MemoryContext context);
+static void PreparedCacheStats(MemoryContext context, int level, bool print, MemoryContextCounters *totals);
+#else
static void PreparedCacheStats(MemoryContext context, int level);
+#endif
static void PreparedCacheCheck(MemoryContext context);
#endif
@@ -160,14 +165,18 @@
static void
+PreparedCacheStats(MemoryContext context, int level, bool print, MemoryContextCounters *totals)
+#else
+#endif
* (see postgis-devel archives July 2007)
+ fprintf(stderr, "%s: Prepared context\n", context->name);
- fprintf(stderr, "%s: Prepared context\n", context->name);
