[postgis-tickets] [PostGIS] #3386: PostgreSQL 9.1 backend failure on debbie when compiling with SFCGAL support
trac at osgeo.org
Mon Nov 30 11:45:16 PST 2015
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.1
Component: postgis | Version: 2.2.x
Keywords: |
Sadly 9.1 is a version we said we'd support in PostGIS 2.2.
http://debbie.postgis.net:8080/job/PostGIS_Regress/2398/consoleFull
regress_sfcgal .. ok
sfcgal/empty .. failed (diff expected obtained:
/var/lib/jenkins/workspace/postgis/tmp/2_2_pg9.1w64/test_107_diff)
--- sfcgal/empty_expected 2015-11-30 18:26:40.635232931 +0000
+++ /var/lib/jenkins/workspace/postgis/tmp/2_2_pg9.1w64/test_107_out
2015-11-30 19:25:24.220663072 +0000
@@ -1,3 +1,4 @@
+ERROR: unrecognized configuration parameter "postgis.backend"
T1.1|POINT EMPTY
T1.2|LINESTRING EMPTY
T1.3|SRID=4326;POLYGON EMPTY
@@ -30,7 +31,7 @@
ST_Intersection(empty, empty) == empty|t
ST_Difference(geometry, empty) == geometry|t
ST_Difference(empty, geometry) == empty|t
-ST_Distance(geometry, empty) == NULL|inf
+ST_Distance(geometry, empty) == NULL|
ST_DWithin(geometry, empty, tolerance) == FALSE|f
ST_Within(geometry, empty) == FALSE|f
ST_Contains(empty, geometry) == FALSE|f
sfcgal/geography .. failed (diff expected obtained:
/var/lib/jenkins/workspace/postgis/tmp/2_2_pg9.1w64/test_108_diff)
--- sfcgal/geography_expected 2015-11-30 18:26:40.923232666 +0000
+++ /var/lib/jenkins/workspace/postgis/tmp/2_2_pg9.1w64/test_108_out
2015-11-30 19:25:24.288663146 +0000
I think it's rare though that people will be using SFCGAL with 9.1. So we
have couple options here:
a) Fix the issue so backend switching works for 9.1. Since we don't
support 9.1 in 2.3, we don't need to make the fix in 2.3
b) Disable SFCGAL testing in 2.2 (at least for 9.1) and tell people to
upgrade if they want to use SFCGAL in 9.1 in 2.2
c) Just stop testing 9.1 on 2.2
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3386>
