[postgis-tickets] [PostGIS] #3311: Base Directory registry Path change in Postgres 9.3.9.3 causes PostGIS install to fail
trac at osgeo.org
Fri Oct 2 11:04:57 PDT 2015
install to fail
Reporter: wsi | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS PostgreSQL
Component: postgis | Version: 2.1.x
Resolution: | Keywords:
Comment (by robe):
wsi How are you installing PostGIS? Sorry not following.
Are you talking about silent installer. I can check the code on that
again but I did put in a silent patch.
Also can you tell me the exact version of PostgreSQL you are using:
SELECT version();
I don't know what that extra digit is you have listed is for - is that the
release number at end of EDB installers?
you are installing and whether 32-bit or 64-bit.
Latest for 9.3 64/32-bit is here -
http://download.osgeo.org/postgis/windows/pg93/
Since I haven't rolled out the 2.1.8 for 9.3, I can put a fix in if I
understand what needs fixing.
I haven't had any issue installing PostGIS on windows with the installers
but admittedly my focus these days is on 64-bit PostgreSQL 9.4, so it's
possible I missed something.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3311#comment:1>
