[postgis-tickets] [PostGIS] #1770: long transaction
trac at osgeo.org
Sat Oct 3 09:25:48 PDT 2015
Reporter: cruizch | Owner: cruizch
Type: patch | Status: new
Priority: medium | Milestone: PostGIS 2.3.0
Component: postgis | Version: 2.0.x
Resolution: | Keywords: long transaction
Comment (by robe):
Yah how did we let it slide. I think part of the reason is that long
transaction support used to only be used by geoserver and unless one of us
is using geoserver, it's hard to verify the patch doesn't break something.
I'm not even sure if geoserver uses that anymore. Not sure if QGIS uses it
and that whole long transaction stuff probably needs a closer revisiting
so the patch may already be obsolete.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1770#comment:10>
