[postgis-tickets] [PostGIS] #3314: Regression tests fail on big endian architectures
trac at osgeo.org
Sun Oct 4 10:18:44 PDT 2015
Reporter: sebastic | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: build/upgrade/install | Version: trunk
Resolution: | Keywords:
Comment (by robe):
yup winnie started failing after pramsey's commit because of the lower
case issue you describe. I'll commit this change in a bit.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3314#comment:3>
