[postgis-tickets] [PostGIS] #3321: Performance regression in topology load
trac at osgeo.org
Wed Oct 7 13:00:52 PDT 2015
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.1
Component: topology | Version: trunk
Resolution: | Keywords:
Comment (by strk):
The time difference becomes worst when the topology is pre-populated.
Here's the case after the first 20k polygons loaded:
-- limit 10k offset 20k real 8m17.509s [2.2.0dev] addLinestring
-- limit 10k offset 20k real 1m53.791s [2.1.9dev] addLinestring
The 2.1.9 version loads 10k polygons in about half the time it loaded 20k
before.
The 2.2.0 version loads 10k polygons in more time than it loaded 20k
before.
It might have to do with index misuse.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3321#comment:5>
