[postgis-tickets] [PostGIS] #3347: Loader functions rely on the order of columns be returned in ordinal_position order (was: county_all, county_all_lookup not loading for Tiger 2015)
PostGIS trac at osgeo.org
Sat Oct 24 14:54:28 PDT 2015
  Reporter:  robe            |      Owner:  robe
      Type:  defect          |     Status:  reopened
  Priority:  blocker         |  Milestone:  PostGIS 2.2.1
 Component:  tiger geocoder  |    Version:  trunk
Resolution:                  |   Keywords:
Changes (by robe):
 * status:  closed => reopened
 * resolution:  invalid =>
Comment:
 Okay there is an issue here.  I'm not sure why I never ran into it before.
 It could be because this particular database has more than a thousand
 tables so the query planner does something different.
 The fundamental issue is that when building list on columns, the loader is
 assuming the columns in information_schema.columns will be returned in
 ordinal position if no order by is specified.  This is not the case with
 this particular database anyway.
 I think someone actually complained about this but I didn't understand why
 they tried to change the load scripts and why it was failing on their
 system.  Anyway it's a simple fix.
 Will test and upport and backport after I have tested my patch.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3347#comment:2>
